Cisco Secure Endpoint Device Control pop-up/logging
SangJun Lee
Hello, I am a Cisco Secure Endpoint beginner.
I want to control USB through Device Control function.
I created a policy to block all USBs except for USBs from certain vendors.
I actually did the test, and I checked the client's pop-up and the log on the Cisco Secure Endpoint Dashboard that it was allowed when I connected USB from a particular vendor.
What I'm curious about is that when I unplug and reconnect the USB, access was allowed normally, but no pop-up was generated in the client, and I couldn't check the log on the dashboard.
I checked all of the Cisco Secure Endpoint guides, but I couldn't find anything about them.
If the USB allowed by policy is allowed once, is it right to operate bypass when the USB is removed and connected again?
If anyone is familiar with this, I hope you can help me.
Please let me know if I'm mistaken.
Thank you.
pheli
Hello
As described in this guide,"Sometimes subsequent insertion events might be skipped because of the throttling limit."
There are some Known Issues and Limitations about Device Control function, you can  refer to the user Guide P59.
If there are unexpected behaviors during your use, you can contact our TAC team for further assistance.
