EMM Connection Code Configuration
Hi there,
I'd like to know if there is a configuration option for using a connection code in an EMM network on Meraki System Manager.
We are trying to achieve the below automation. We can currently deploy the iOS app but we'd like to deploy it and have it already licensed and assigned to our management portal.
https://docs.sophos.com/central/Mobile/help_ixm/en-us/AdminHelp/MTDWithIXM/ThirdPartyEMM/index.html
Arthur Dent
add the app to Systems Manager.
Then, go to Systems Manager > Settings and click the + in the top right hand corner
Create a new Device Profile
Click the + on the left hand side and add managed App Config
Select the device platform, then the newly added application
You'll now be able to add the keys and values relevant to the app
A bit more info, this is achieved similar to MacOS custom app arguments
Arthur Dent
