Issues enrolling Android device
BlakeRichardson
Meraki Community All-Star
So I dipped my toe into the management of Android devices this morning, I have been managing iOS device using SM for years but never Android.
So everything is setup behind the scenes in Meraki and Google workspace and everything looks happy. The problem is I have just gone to register the first device and scanned the QR code as well as signed into the appropriate Google account and now I have this stuck on the screen with the progress bar getting to the end and then going back to the start and the device now appears to be stuck in a loop.
Any ideas or have I made the mistake of trying to manage Android devices 😂
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
6 Replies 6
Philip D'Ath
Does the device say it supports Android Enterprise? Only Android Enterprise devices can be managed.
BlakeRichardson
UPDATE restarting the device and giving the SM app write access to the couple of things fixed the issue. Off that it didn't ask for that before trying to enrol but it's working now.
BlakeRichardson
What I found is this screen as well as having the enrol option also has two other options, one related to permissions for writing to the device and I can't remember what the other is ( I will take a picture next time)
If you don't allow write access thats when it gets stuck in a loop.
Arthur Dent
You shouldn't have any need to sign into anywhere, unless you have enrollment authentication turned on.
I'm assuming that:
You tapped the screen 6 times
Scanned the QR Code
And the device enrolled?
BlakeRichardson
@Arthur Dent tapping the screen 6 times didn't do anything for me even though its a brand new device.
beks88_
Level 2
Level 2
I'm waiting for the support of "fully managed device with a work profile"
If you are using/testing only device owner mode (fully managed device), I would recommend you to use Android Zero Touch enrollment because it offers the same experience like Apple ADE.
If you are not a registered Android Partner, try to enroll otherwise just find a device reseller as partner
Systems Manager enthusiast
