Configuration backup using ASDM
suthomas1
Level 7
Level 7
Similar to the way we log configuration when doing changes via CLI for PIX/ASA to get backup configs before changes, is there a way same practice can be followed with ASDM as well.Because ASDM is webbased.
Please advice.
Thanks.
Hi Sunny,
If you look under the "File" menu in ASDM you will see a few options for viewing and saving the running config. The easiest way is probably to select "Show running configuration in new window" and copy or save it from the window that opens.
Hope that helps.
-Mike
