startup-config won't load
ucsd92126
I got ASA 5510 ver 8.2.  Every time when I cold boot the ASA the startup-config not load.  I have to get into the console and manually run the load command to startup.  What do I need to make it the startup-config automatic load?
Nelson
Jon Marshall
Nelson
Can you post a "sh version" from the firewall ? It sounds like your config register value may be wrong.
Jon
Please check the attachment.
Nelson
Nelson
Your config register is 0x0 at the moment. You should change it to 0x1 ie.
ASA# config-register 0x1
Jon
Cisco are currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
