What is chunk:parser csb?
jsmith_tnsi
Community Member
I have a fwsm and I ran:
show resource usage context <device name> detail
I got the following result:
Resource               Current               Peak               Limit               Denied               Context
chunk:parser csb     4294967295          8                  Unlimited               0               <Device name>
Everything appears to be working fine but I am curious about the high number of 4294967295.
Thanks.
Jay
brquinn
Level 6
Level 6
Jay,
The chunk means that the memory is allocated from a larger memory pool by the memory chunker. I'm not sure exactly what parser csb is, but what you are seeing looks like a cosmetic bug. That is an invalid value at the upper limit for a 32-bit integer.
Brendan
