TCL - WakeOnLan on Router
Petr Kriz
I have got TCL script (uploaded on flash on router) for WakeOnLan.
proc WakeOnLan { macAddr } {
     set net [binary format H* [join [split $macAddr -:] ""]]
     set pkt [binary format c* {0xff 0xff 0xff 0xff 0xff 0xff}]
     for {set i 0} {$i < 16} {incr i} {
        append pkt $net
     # Open UDP and Send the Magic Paket.
     set udpSock [udp_open]
     fconfigure $udpSock -translation binary \
          -remote [list 255.255.255.255 4580] \
          -broadcast 1
     puts $udpSock $pkt
     flush $udpSock;
     close $udpSock
if { $::argc > 0 } {
    set i 1
    foreach arg $::argv {
    WakeOnLan $arg
    incr i
When I run the script via command
tclsh flash:WakeOnLan.tcl <MacAddress>
I received an error
invalid command name "udp_open"
    while executing
"udp_open"
    (procedure "WakeOnLan" line 10)
    invoked from within
"WakeOnLan $arg"
    ("foreach" body line 2)
    invoked from within
"foreach arg $::argv {
    WakeOnLan $arg
    incr i
    invoked from within
"if { $::argc > 0 } {
    set i 1
    WakeOnLan $arg
    incr i
    (file "flash:WakeOnLan.tcl" line 19)
Thsi error I understand, but I can't find a solution how can I this error resolve.
Additional informations - device for testing:
  • Device: Cisco 1811
  • ROM: System Bootstrap, Version 12.3(8r)YH5, RELEASE SOFTWARE (fc1)
  • System image file is "flash:c181x-advipservicesk9-mz.124-24.T3.bin"
Thank you and best regards,
 Petr
Alexander Stevenson
Hi @Petr Kriz,
Did you happen to get that script from here? --> https://blog.ipspace.net/2011/11/sending-wake-on-lan-wol-packet-with-ios.html
If so, you missed adding broadcastAddr on line 1 and you hardcoded it into line 23. Those small differences could mean the difference.
However, I'm guessing the indentation may be the problem. I copied and pasted your code into VS Code and ran a TCL formatter I downloaded for free from the VS Code Marketplace. It adjusted your indentation. Not sure if that will fix your issue, but it's worth a try.
Formatted code:
        append pkt $net
        -broadcast 1
    puts $udpSock $pkt
    flush $udpSock;
    close $udpSock
    set i 1
        WakeOnLan $arg
        incr i
I've attached the formatted version of the file as well. I had to make it into an .rtf file because the uploader here isn't recognizing the tcl file extension.
Hope this helps.
Alexander Stevenson
Here is a newer version of the code you're running, but without the IF function --> https://blog.protocolsyntax.com/2015/07/29/tcl-wol-on-cisco-router/
Maybe that part is the problem??
