Creating a Tidal job, which continuously iterates execution 7x24
Dave.Carnahan
To create a Tidal job to continuously iterate execution:
  1. Create a parent (row) job, and tell it (if needed) to wait xxxx minutes before repeating (if needed between iterations)
  2. Create the Tidal job (row), within the parent job (above).
  3. Create several Tidal job events as follows:
    1. Tidal 'job event(s)' for if:
      1. Job becomes externally defined (output pending)
      2. Job becomes 'completed abnormally'
      3. Job becomes 'externally defined'
      4. Job becomes 'orphaned'
    2. For the above 'job events', define that they 'set to Completed Normally'
    3. Assign the above events to [1] the Tidal job (row) and [2] the Tidal job parent (row).
0 Replies 0
