Help Installing Command Line
westdgubbels
Community Member
Does anyone have some helfpful hints in regards to installing the
Enterprise Scheduler CommandLine.msi for Windows.for Tes 6.1.0
I believe it is to be installed on the Master, backup Master -- does it also need to be installed on the Fault Monitor?
Thank you
Donna
I don't have it installed in FM, only on master and BM.  Installation is fairly straigforward except the part when you actually have to use it - like knowing what user can run it and the parameters to use ( you can reference the TES 6.1 PDF docs for that)
The only tip I have if you want to schedule running  the command line from  within Tidal itself  is to also presave the password (I think its called persistance) so that you are not referencing connection parameters/credentails in every job parm.  There is also instructions on doing that around the forum and PDFs I believe.
