How to make a job group loop
pkaur0001
I know we can create a new instance a job group at specific minute intervals, but is there a way to create a new instance when the first instance has finished running?
Tracy Donmoyer
1) Create a Job Action to insert the job group
2) Create a Job Event to run the Job Action when the job completes normally
3) Add the Job Event to the job group or the last job to execute in the group.  When the job group completes normally it will trigger the Job Event to run the Job Action and insert a new instance of the job group.
Good luck.
Tracy
