Issues with Transition Automation Packs
vnamboot
We are facing an issue with transition automation packs. We have an extended property which is (became) part of "Transition Automation Pack for 'Cisco Systems, Inc." And we do not see any option to remove the same. We can see that certain other automation packs have the option to remove (remove button). Any idea, on what could be the issue? or Any comments?
Vijay
Von Jones
Level 4
Level 4
It's my understanding that you cannot remove an automation pack if there are dependencies on it.  Perhaps your content has references to the extended target properties in this automation pack.
Shaun Roberts
Could you post a SS of the object tab of that automation pack and then dependencies tab?
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
