Moment global variable values
lim.park01
In ISF/Javascript, what are all the values for the Moment global variable?
For example, (Moment == "ordering") can be used to check if the current moment is Ordering moment. What are the values for all other moments, specifically Service Group Review and Service Group Authorization moments?
Thank you.
sotoh
The values for Service Group Review moment is "streviews" and Service Group Authorization moment is "stauthorizations".
You are correct that these are not in the designer documentation.  One way you can find them is through view page or frame HTML source when the service form is in that particular moment, and look for the word "Moment".
Thanks for the information.
Any chance these details get added to documentations?
Yes, we will add them into the service design documentation.
