Schedule the Python script from Tidal
gaurav_verma1
Community Member
I am not able to schedule any python script from Tidal. Its giving me error:
Launcher Error: startup dir error[/usr/local/bin/python test.sh]:- No such file or directory
Triton Agent Error -14
I scheduled the below command in job window under command section
/usr/local/bin/python /home/test.sh
but it gave me the above error....
But if i try to run any shell i am fine it runs as i can make shell script as executable and schedule from Tidal something like this:
/home/test.sh
Please let me know if we have some way to schedule any python/java program from Tidal
Gaurav
7 Replies 7
sdonnelly1
Community Member
The problem is the space in the file name. I am still looking for a solution to the issue, but so far no luck. The only other option would be to change the file name to not have a space. Using an underscore instead of a space worked for us.
Hope you have tried enclosing the command within single or double quotes ?
'/usr/local/bin/python /home/test.sh'
"/usr/local/bin/python /home/test.sh"
I have tried and nothing seems to work. Mine is:
/opt/TIDAL/order process/wait.sh
How about
/usr/local/bin/python "/opt/TIDAL/order process/wait.sh"
Derrick Au
Level 9
Level 9
Hi Gaurav,
Please check your path settings, type env
You may have to add /usr/local/bin/python to your PATH, type
setenv PATH $PATH\:/usr/local/bin ; export PATH
BR,
Derrick Au
Hi Derrick
If we are using the direct path to the program such as /usr/local/bin/python, then why do we need to add it to $PATH ?
It is not necessary to add it to the PATH but it will save on the typing in the long run. I usually do something simple like that to take my mind away from the problem, then later come to realize: using python to run a shell script (.sh) usually leads to a syntax error, so when start up file or directory is not found, then maybe Python isn't installed on that particular machine--try which python 😉
