Tidal repository Query for Jobs, Dependencies, Parameters.
smk.muthu
I am new to Tidal. I am looking for a query to extract the data about Jobs from Tidal repository DB.
The information i am looking for are as follows. Does tidal have any predefined reports which provide this information  which has below information ?
Application Name
Job Level
Job Name
Active/Inactive Indicator
Parameters
Internal Job Type
Predecessor JN
Successor JN
Schedule Type
Scheduled Time
We have jobs nested jobs and have 20,000 tidal jobs.
Thanks in advance
Muthukumar.S
Derrick Au
Level 4
Level 4
Hi Muthukumar,
Welcome new Tidal user. Is your DB Oracle or SQL?
In the meantime, a lot of the information you are looking for is already available from the job definition screen: Level, Job ID, Name, Enabled/Disabled, Program/Command, Parameters, Job Type, Job From, Job Until etc.
Upper left hand corner, click on File -> Export
File can be saved as csv and then uploaded into MS Excel for reviewing
BR,
Derrick Au
Hi Derrick,
Was looking for answer to my question thought may be you can help me out.
I just wanted to know if there is any parameter for JobDependency that we can pass into output of job. For example if any of job dependency fails out I can see in job output whether which dependency has failed.
