TIDAL throwing rogue exit codes
SIMMS7400
Hello Team -
I'm having an issue in TIDAL where upon exit of the job, its throwing the incorrect EXIT code (i.e. other than 0).  Upon further inspection, the batch file which TIDAL said had an Abnormal Exit, completed successfully as indicated by my verification and my log file that is also spooled.
Please see attached screen shot.  Does anyone else have this issue and how should I get around it? Thanks!
Dan Lukes
Feedback forum is dedicated to other topics. Moved to Tidal Enterprise Scheduler
Derrick Au
Level 4
Level 4
Hi Simms7400
In your Job Definition->Run tab, you can scan output/string for normal completion. That way, every time when the job runs and completes with SUCCESS in the output, then the job will complete normally.
But I am curious as to what step/process might be sending a return code back to Tidal not equal to zero. Perhaps that is worth investigating further.
BR,
Derrick Au
