xPath Query
esramasa
Hi All,
How to use Xpath query . I need a example of Xpath query activity in CPO.
Warren Ackerman
Same with this request. This information is in the design center.
Shaun Roberts
XPATH query is a pretty standard XML/web query language. You can review it in general @ http://www.w3schools.com/xpath/xpath_syntax.asp
For CPO examples, I suggest you go check out the design center and/or my blog (which is public to all).
The blog is called Pondering Automation and is @ https://supportforums.cisco.com/community/5811/intelligent-automation
I do a ton of web service work with JSON, XML, Xpath queries , etc.
Also here if you are more specific with your use-case about what you are doing it might be more easy for us to help and everyone to benefit from it.
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
