Wireless authentcation failed
MAK6
We are using radius server win server 2019 ,facing an issue while sending a radius authentication request from wireless Cisco 3800 to radius server below log showing on event viewer
Level Date and Time Source Event ID Task Category
Information 8/21/2022 4:05:00 PM Microsoft-Windows-Security-Auditing 6273 Network Policy Server "Network Policy Server denied access to a user.
Contact the Network Policy Server administrator for more information.
User:
Security ID: NULL SID
Account Name:
Account Domain: xxx
Fully Qualified Account Name: xxx
Client Machine:
Account Name: -
Fully Qualified Account Name: -
Called Station Identifier:
Calling Station Identifier: xxxx
NAS:
NAS IPv4 Address: xxxx
NAS IPv6 Address: -
NAS Identifier: xxxx
NAS Port-Type: Wireless - IEEE 802.11
NAS Port: 1
RADIUS Client:
Client Friendly Name: xxxx
Client IP Address: xxxx
Authentication Details:
Connection Request Policy Name: Secure Wireless Connections
Network Policy Name: -
Authentication Provider: Windows
Authentication Server: xxxx
Authentication Type: PAP
EAP Type: -
Account Session Identifier: 36333032326437632F30303A31313A32323A33333A34343A35352F3332333835
Logging Results: Accounting information was written to the local log file.
Reason Code: 16
Reason: Authentication failed due to a user credentials mismatch. Either the user name provided does not map to an existing user account or the password was incorrect.
Take a look at this:
Is using PAP protocol for authentication . Allow PAP in win server and try again:
8 Replies 8
ammahend
Seems like everything is working and user is getting denied because of mismatched credentials. Are you sure you are using correct credentials ? And your supplicant is configured correctly for whatever eap method you are using.
-hope this helps-
Hello ammahend
Well i checked the credentials many times its look fine ,let me share the picture of supplicant defined method in win server
I don’t see any picture, can you share supplicant config (client side) as well, I can tell if it’s configured correctly.
-hope this helps-
MAK6
Same error getting after enabling pap even.
I think you have some missing config in your deployment. Take a look at this link NPS, Wireless LAN Controllers, and Wireless Networks Configuration Example - Cisco and check your config. If you see that everything is fine ,reply  the post with a debug client and a debug aaa command on the WLC and i will try to help you (debug client "mac-address" and debug aaa enable) . After that don`t forget to undebug all .
MAK6
