Hi All
I am facing issue with ACE load Balancer,
SERVER-------------(http)-------------ACE----------------(https)---------------Client
Here If I removed https configuration I m able to work with Server but If put ssl configuration in ACE, client is not getting any prompt for dowload active x control and not able to work with application. He received only white blank page. This issue with Virtual IP (z.z.z.z)
If I access real server IPs it work smooth for me.!!
resource-class STICKY
limit-resource all minimum 0.00 maximum unlimited
limit-resource rate connections minimum 10.00 maximum unlimited
limit-resource sticky minimum 10.00 maximum unlimited
probe http HTTP_PROBE
interval 20
passdetect interval 40
receive 3
expect status 0 499
connection term forced
open 1
parameter-map type ssl PARAMMAP_SSL_TERMINATION
cipher RSA_WITH_3DES_EDE_CBC_SHA
cipher RSA_WITH_AES_128_CBC_SHA priority 2
cipher RSA_WITH_AES_256_CBC_SHA priority 3
rserver host Ser1
ip address x.x.x.x1
probe HTTP_PROBE
inservice
rserver host Ser2
ip address x.x.x.x2
probe HTTP_PROBE
inservice
serverfarm host HTTP
rserver Ser1 80
inservice
rserver Ser2 80
inservice
ssl-proxy service SSL_PSERVICE_SERVER
key MYKEY.PEM
cert MYCERT.PEM
ssl advanced-options PARAMMAP_SSL_TERMINATION
sticky ip-netmask 255.255.255.255 address source STICKY
replicate sticky
serverfarm HTTP
class-map match-all L4_SSL-TERM_CLASS
2 match virtual-address z.z.z.z tcp any
policy-map type loadbalance http first-match PM
class class-default
sticky-serverfarm STICKY
policy-map multi-match PM-MULTI-MATCH
class L4_SSL-TERM_CLASS
loadbalance vip inservice
loadbalance policy PM
loadbalance vip icmp-reply
Service-Policy Is already applied, please let me know if you have any idea for this case?
