ACE Load Balancer With ActiveX problem
jignesh.darji
Community Member
Hi All
I am facing issue with ACE load Balancer,
SERVER-------------(http)-------------ACE----------------(https)---------------Client
Here If I removed https configuration I m able to work with Server but If put ssl configuration in ACE, client is not getting any prompt for dowload active x control and not able to work with application. He received only white blank page. This issue with Virtual IP (z.z.z.z)
If I access real server IPs it work smooth for me.!!
resource-class STICKY
  limit-resource all minimum 0.00 maximum unlimited
  limit-resource rate connections minimum 10.00 maximum unlimited
  limit-resource sticky minimum 10.00 maximum unlimited
probe http HTTP_PROBE
  interval 20
  passdetect interval 40
  receive 3
  expect status 0 499
  connection term forced
  open 1
parameter-map type ssl PARAMMAP_SSL_TERMINATION
  cipher RSA_WITH_3DES_EDE_CBC_SHA
  cipher RSA_WITH_AES_128_CBC_SHA priority 2
  cipher RSA_WITH_AES_256_CBC_SHA priority 3
rserver host Ser1
  ip address x.x.x.x1
  probe HTTP_PROBE
  inservice
rserver host Ser2
  ip address x.x.x.x2
  probe HTTP_PROBE
  inservice
serverfarm host HTTP
  rserver Ser1 80
    inservice
  rserver Ser2 80
    inservice
ssl-proxy service SSL_PSERVICE_SERVER
  key MYKEY.PEM
  cert MYCERT.PEM
  ssl advanced-options PARAMMAP_SSL_TERMINATION
sticky ip-netmask 255.255.255.255 address source STICKY
  replicate sticky
  serverfarm HTTP
class-map match-all L4_SSL-TERM_CLASS
  2 match virtual-address z.z.z.z tcp any
policy-map type loadbalance http first-match PM
  class class-default
    sticky-serverfarm STICKY
policy-map multi-match PM-MULTI-MATCH
  class L4_SSL-TERM_CLASS
    loadbalance vip inservice
    loadbalance policy PM
    loadbalance vip icmp-reply
Service-Policy Is already applied, please let me know if you have any idea for this case?
praprama
Hi Jignesh,
You might want to move this question to the application networking community as it is to do wit ACE:
https://supportforums.cisco.com/community/netpro/data-center/application-network
Thanks and Regards,
Prapanch
