ASA 5506W wifi setup problem
erikorrsjo
Visitor
I have problems getting to the webinterface for configuring the ASA5506W wifi.
According to the documentation, the access point should get the IP-address 192.168.10.2.
I can't reach that IP from a computer on the "inside"-interface of the ASA. Pinging the IP from the ASA does not work either.
I read somewhere that reseting the wifi-device using
hw-module module wlan recover configuration
would help, but it didn't do anything for me.
Anyone got any suggestions?
/Erik
12 Replies 12
Henrik Rostgaard Soerensen
Community Member
Hi Erik.
Did you solve this issue ?
I'm in the same situation.
/Henrik
Can you post the config from the ASA device ?
Thanks and Regards,
Vibhor Amrodia
Sure Vibhor.
Here you are.
/henrik
Have you solved this?
My main problem was that I had not configured correct NAT properly between the interfaces.
Hi erikorrsjo.
No unfurtunaly not.
Can you specify the solution you found?
Best regards
Henrik
Hi Henrik,
Try following:
asa# session wlan console
ap>enable
Password: Cisco
ap#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
ap(config)#ip default-gateway 192.168.10.1
ap#copy run start
Then try accessing the wlan GUI.
Hope it helps!!!
R.Seth
Thanks R.Seth.
But I have tried that and onces again right now.
I not able to open the GUI in any way I have found in the documentation.
http://192.168.10.1
https://192.168.10.1
http://192.168.10.1:1065
http://192.168.10.2
https://192.168.10.2
http://192.168.10.2:1065
I'm out of ideas now.
/Henrik
Hi Enrik,
Try following:
ap>enable
Password: Cisco
ap#copy run start
Hope it helps!!!
R.Seth
Thanks R.Seth
I'll try this on monday then I'm at the office again.
/Henrik
Hi, I have a problem, I don't know if my asa 5506 is wireless, in the chasis have the logo of wifi and have the leyend the "wifi model only", but i don't see the G1/9 and the command: "hw-module module wlan recover configuration"  isn't accepted.
I need help, please!
Hi tadashikanamori, the white label on the buttom of the chassis, should say ASA5506W if it has the WIFI option.
Best regards
Henrik.
The problem is that http server is not enable by default.
From the asa, console to AP
ciscoasa# Session wlan console
Ap> enable secret (you must change the default secret to configure)
Ap# conf t
Ap# ip http server
Ap# ip default-gateway 192.168.10.1
Copy run start
