ASA ASDM problem
junshah22
Level 5
Level 5
Dear All,
I am trying to configure my ASA 5510, I restored it to factory default settings by using
(config)#configure factory-default
now,, in the books, the author said, by default there is no username and password to sign in into the ASA,, but when i open my browser and enter https://192.168.1.1 it asks for a username and password,
when i simply clicked on submit button without entering any username and password,, it doesn't go forward,,
then I made a username and password on ASA using
username ------ password ------ command
now, it accepted the password,, but not launching its software,,, it hangs on the dialog window
Cisco ASDM Launcher,,
Device Ip
username
password,,
I also tried to use JAVA based configuration,, but when i open the window,, it shows a message, ble to load application, Exception in Starting Main wi
I updated my Java Runtime by downloading it from java.com but no result,,
Please help,
5 Replies 5
abinjola
use java6 update 7
I am using Java 6 update 13,,
do i need to uninstall update 13 and to switch back to update 6?? if yes, hows it possible?
Please advise
Junaid
I had the same issue before with Win Vista and java 6.13 in 2 laptops. In the end I giveup and i'm using XP with Java 6.13, and it work fine.
I hope it's not a bug!
Reda
I am currently using Windows XP,, should i try with vista??
chip.wagner
There is a know issue with the newer versions of Java Runtime, and asdm-615.bin
(ASDM) I had to uninstall my Java, and back rev to 1.6.0_07, this version runs fine.Just make sure you turn off auto updates.
