ASA Ping Problem
saeedaraghi
Visitor
Hi dears
I have a problem with Cisco ASA.
I have 2 Cisco ASA that are connected to each other with outside interfaces, The IP range between these is 50.50.50.0 and the outside IP ranges are 10.10.10.0 and 20.20.20.0.
In ASA-1: I have ping to outside and inside interfaces but There is no ping to inside interface of ASA-2.
In ASA-2: I have ping to outside and inside interfaces but There is no ping to inside interface of ASA-1.
The Device`s in inside interface ASA-1 cannot ping the device`s in inside interface ASA-2.
The ASA configure is shown below:
hostname ASA-1
interface g0/0
nameif Outside
security-level 100
ip address 50.50.50.1 255.255.255.0
NO SHUT
exit
interface g0/3
nameif Inside
security-level 100
ip address 20.20.20.1 255.255.255.0
NO SHUT
exit
access-list 100 extended permit ip any any
access-list 100 extended permit icmp any any echo-reply
access-list 100 extended permit icmp any any source-quench
access-list 100 extended permit icmp any any unreachable
access-list 100 extended permit icmp any any time-exceeded
access-list 100 extended permit tcp any any
access-list 100 extended permit udp any any
access-group 100 in interface Outside
access-group 100 out interface Outside
access-group 100 in interface Inside
access-group 100 out interface Inside
route Outside 10.10.10.0 255.255.255.0 50.50.50.2 1
hostname ASA-2
interface g0/0
nameif Outside
security-level 100
ip address 50.50.50.2 255.255.255.0
NO SHUT
exit
interface g0/3
nameif Inside
security-level 100
ip address 10.10.10.1 255.255.255.0
NO SHUT
exit
route Outside 20.20.20.0 255.255.255.0 50.50.50.1 1
I use these commands that was recommended in Cisco Doc too:
policy-map global_policy
class inspection_default
inspect icmp
exit
but nothing changes!
Julio Carvajal
Hello Saeed,
First of all by design you cannot ping the IP of an interface from a distant Network
Let me explain you this with this:
20.20.20.0------ASA------50.50.50.0
So you can ping from the 20.20.20.0 /24 network to the inside interface of the ASA (20.20.20.1) but you cannot ping the outside interface ( 50.50.50.1) from the inside network this as a Security design.
Now second this the host are not being able to ping because you are missing this command:
- Same-security-traffic permit inter-interface
Please let me know if this help you, If not I would be more than glad to keep troubleshooting this.
Best Regards,
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
6 Replies 6
troullier00
Community Member
I believe you are looking for the ICMP command. This command let's you specify which host or networks are allowed to ping the ASA box.
Julio Carvajal
Hello Saeed,
Best Regards,
Julio Carvajal
Hello dear Jcarvaja
Thank you very much for your answer, this command works well!
But the original solution is this:
20.20.20.0/24 ------ (ASA-1) ------ X.X.X.100 ------- (internet) ------ Y.Y.Y.101 ------ (ASA-2) -----10.10.10.0/24
And I need a tunnel between ASA-1 and ASA-2 on the Internet, and now my problem is:
hostname ASA-1
interface g0/0
nameif Outside
security-level 0
ip address X.X.X.100 255.255.255.224
NO SHUT
exit
interface g0/3
nameif Inside
security-level 100
NO SHUT
exit
access-list Inside_nat0_Outside extended permit ip 20.20.20.0 255.255.255.0 10.10.10.0 255.255.255.0
access-list Outside_1_Cryptomap extended permit ip 20.20.20.0 255.255.255.0 10.10.10.0 255.255.255.0
global (Outside) 1 interface
nat (Inside) 0 access-list Inside_nat0_Outside
nat (Inside) 1 20.20.20.0 255.255.255.0
route Outside 0.0.0.0 0.0.0.0 X.X.X.99 1
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto map Outside_map 1 match address Outside_1_Cryptomap
crypto map Outside_map 1 set peer Y.Y.Y.101
crypto map Outside_map 1 set transform-set ESP-DES-SHA
crypto map Outside_map interface Outside
crypto isakmp enable Outside
crypto isakmp policy 10
authentication pre-share
encryption des
hash sha
group 1
lifetime 86400
tunnel-group Y.Y.Y.101 type ipsec-l2l
tunnel-group Y.Y.Y.101 ipsec-attributes
pre-shared-key 1234
hostname ASA-2
interface g0/0
nameif Outside
security-level 0
ip address Y.Y.Y.101 255.255.255.224
NO SHUT
exit
interface g0/3
nameif Inside
security-level 100
NO SHUT
exit
access-list Inside_nat0_Outside extended permit ip 10.10.10.0 255.255.255.0 20.20.20.0 255.255.255.0
access-list Outside_1_Cryptomap extended permit ip 10.10.10.0 255.255.255.0 10.10.10.0 255.255.255.0
nat (Inside) 1 10.10.10.0 255.255.255.0
route Outside 0.0.0.0 0.0.0.0 Y.Y.Y.50 1
crypto map Outside_map 1 set peer X.X.X.100
encryption des
hash sha
group 1
lifetime 86400
tunnel-group X.X.X.100 type ipsec-l2l
tunnel-group X.X.X.100 ipsec-attributes
pre-shared-key 1234
Hello Saeed,
You dont have to thank me , It is a pleasure to be able to help you.
On ASA 2, Would yo change this Access list.
to this one
access-list Outside_1_Cryptomap extended permit ip 10.10.10.0 255.255.255.0 20.20.20.0 255.255.255.0
With this we are allowing as interesting traffic over the VPN tunnel all the IP traffic comming from 10.10.10.0 to 20.20.20.0.
Also You got to have this command on both ASAs :
management-access Inside
Please let me know if this works
Best Regards,
Julio Carvajal
Hello jcarvaja again
Thank you for your help, I did things that you said but nothing changed, I have no ping and no active tunnel.
  • •1. I fixed this:
On ASA-2
  • •2. And I add this command:
Management-access inside
On both ASA
I have one server with IP: 20.20.20.20 on ASA-1and one PC with IP: 10.10.10.10 on ASA-2.
There is no ping from inside ASA-1 to inside ASA-2 but the outside ASA-1 can ping outside ASA-2 and
ASA-1 can ping 20.20.20.1-20 and ASA-2 can ping 10.10.10.1-10
I think the problem is about my tunnel,
Global IKE Statistics
Active Tunnels: 0
Previous Tunnels: 0
IPsec Global Statistics
Active tunnels: 0
Previous tunnels: 0
show crypto ipsec sa
There are no ipsec sas
show crypto isakmp sa
There are no isakmp sas
hostname ASA-1
interface g0/0
nameif Outside
security-level 0
NO SHUT
exit
interface g0/3
nameif Inside
security-level 100
NO SHUT
exit
route Outside 0.0.0.0 0.0.0.0 X.X.X.99 1 ---------> to gateway
crypto map Outside_map 1 set security-association lifetime kilobytes 10000
encryption des
hash sha
group 1
lifetime 86400
pre-shared-key 1234
management-access inside
hostname ASA-2
interface g0/0
nameif Outside
security-level 0
NO SHUT
exit
interface g0/3
nameif Inside
security-level 100
NO SHUT
exit
route Outside 0.0.0.0 0.0.0.0 Y.Y.Y.50 1 ---------> to gateway
encryption des
hash sha
group 1
lifetime 86400
pre-shared-key 1234
Hello Saeed,
Actually the configuration seems to be the required one.
This might be a routing issue.
Would you mind to try this packet tracer on ASA 1
Packet-tracer input inside icmp 20.20.20.3  8 0 10.10.10.3
Please let me know the input of this command.
Best Regards,
Julio Carvajal
