07-22-2015 04:23 AM - edited 03-11-2019 11:18 PM
Hi!
I have a new 5506W-X (wifi model).
I have problem accessing the wifi setup, ref to the quick-quide:
On the computer connected to the ASA inside network, launch a web browser.
2.
In the Address field, enter http://192.168.10.2. You are prompted for the username and password.
3.
Enter the username Cisco and the password Cisco. The access point GUI appears.
But i`m unable to open 192.168.10.2 or ping the ip.
I can see the interface 1/9 is up with 192.168.10.1 (asa ip) and dhcp enabled with range 192.168.10.2-200
Cannot find any config for ip 192.168.10.2
Config guide for 5506 has no more info regarding wifi setup.
Any tips?
Erik
07-22-2015 11:57 AM
Hi Erik,
As per your description, i could see that the ASA is configured with DHCP range 192.168.10.2-200. Therefore your access-point has received IP address from DHCP.
As you have mentioned that your computer is connected to ASA inside interface network(expecting that PC is getting IP in range 192.168.10.x), i expect the traffic to directly go to 192.168.10.2 without going through ASA.
Please check if the your access-point is configured correctly. or If you need to access it through 'https instead of http'.
Please let me know if you have any query on this.
Regards.
Akshay Rastogi
11-11-2017 04:58 PM
Not able to access the 192.168.10.2 URL -- Does anybody have the right information? could we get set up via command instructions?
11-12-2017 03:31 AM
Hi @erik bakke
Run the command "hw-module module wlan recover configuration"
Try again and let me know.
-If I helped you somehow, please, rate it as useful.-
