Backup Solution for VPN Connection (using ISDN)
jsteffensen
Level 5
Level 5
We use a VPN Connection between two sites, A=10.1.x.x and B=10.2.x.x., using 2 Pix'es.
The VPN connection works perfectly, well it works perfectly 80% of the time.....
Our different Serviceproviders have some time problems to deliver connection between our sites, and this makes the VPN connection break down some times.
And now we are searching for a BACKUP-Solution for the VPN connection.
We have desided to use ISDN.
By plasing a Router in front (LAN) of the Pix as the Default Gateway for the LAN, we have been thinking that it could use a Routing protocol to detect when the VPN fails, and use the ISDN as the "backup"-connection to the oter site.
It would then look something like this:
LANA - R - Pix ------ VPN ---- Pix - R - LANB
.............\_________ISND________/.........
Primary connection from A to B is the VPN, but if no Routing updates are recieved from the Router on Network B to the Router on LANA, the Router on LANA should use the ISDN connection as Route to LANB.
It cannot be impossible, but does anyone know how?
Or have any Ideas? Brainstorming?
Best Regard
Jarle
8 Replies 8
kstaniek
Community Member
You can try to establish GRE tunnel between routers throught the VPN connection and configure some routing protocol runing on it. When the tunnel will be broken the ISDN backup could be initiated
m.luethi
Community Member
Jarle, have you found a solution? I'm planning on doing exactly the same VPN backup over ISDN.
Thanks for any input!
Martin
MBILA
Community Member
Can you run OSPF on the ethernet ports at both ends of the VPN. Assign IP addresses with the neighbors statement. Because broadcasts will not work. Then use floating static routes for the ISDN.
This is what I will be attempting, I think. What do you think?
MBILA
Community Member
Have you found a solution for this. I am trying to do the same thing?
cjacinto
Be best to run gre on both routers behind the PIX and run some routing protocols over it, say OSPF.
You could then assign a higher metric to the ISDN link, but if route to the GRE tunnel is down (as a consequence of the VPN tunnel being down) then DDR on the ISDN would kick in.
wbutcher
Community Member
Hi Jarle,
Did you get a response to your question? We are about to undertake a project to test ISDN backup to a VPN and any information or resolutions you have would be very useful.
Cheers
Warren
Hi Warren
No I am sorry, I have only some few "notifications" regarding this problem and a possible "workaround":
-Define a GRE tunnel between two routers.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/inter_c/icdlogin.htm#xtocid292793
Since we can live with the problem, we have not invested more in to solving it..........
(If you are able to solve it, i would be grateful for a feedback.....)
Greetings
Jarle
yusuff
Here is a document i wrote, might help
Configuring IPSec Redundancy over ISDN
http://www.cisco.com/warp/public/707/ipsec_dialerwatch.html
R/Yusuf
