Beginner needs help - ASA 5510 Configuration
tsherven1
Ok...I'm struggling here. I have always used Watchguard products, and decided to step up and buy my first Cisco. I'm finding that the configuration is not quite as easy, and would love to get some help.
I have a very simple setup. I need to setup my internal interface, external interface, NAT for 2 addresses (OWA and Exchange),No DMZ, no web server.
I took a crack at the configuration using ASDM 5.0 and the Startup Wizard and failed. questions:
1) Does the external ethernet port have to be ethernet port 0? Right now my internal port is port 0.
2) How are security levels used? How do I need to use them in my setup?
3) Should I be able to use ASDM for all of my setup?
4) Do I need to use DHCP on the ASA?
5) Next steps?
info:
External IP: 64.179.10.28
Gateway IP: 64.179.10.1
Internal interface IP: 192.168.0.x
SMTP IP: 64.179.10.29 (NAT to 192.168.0.x)
OWA IP: 64.179.10.32 (NAT to 192.168.0.x)
Anyone see what I've done wrong? Any help would be appreciated!
Result of the command: "show running-config"
: Saved
ASA Version 7.0(7)
Hostname test
domain-name test.net
enable password xxx
names
dns-guard
interface Ethernet0/0
nameif Internal
security-level 100
ip address 192.168.0.x 255.255.255.0
interface Ethernet0/1
nameif External
security-level 0
ip address 64.x.x.28 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
passwd xxx
ftp mode passive
access-list Internal_access_in remark WWW
access-list Internal_access_in extended permit tcp host 192.168.0.0 eq www interface External eq www
access-list External_access_in remark SMTP
access-list External_access_in extended permit tcp host 64.179.10.29 eq smtp host 192.168.0.53 eq smtp
access-list External_access_out remark HTTP
access-list External_access_out extended permit tcp 64.179.10.22 255.255.255.240 eq www any eq www
pager lines 24
logging asdm informational
mtu Internal 1500
mtu External 1500
mtu management 1500
asdm image disk0:/asdm-507.bin
no asdm history enable
arp timeout 14400
global (External) 10 64.179.10.29-64.179.10.32 netmask 255.255.255.0
nat (Internal) 10 0.0.0.0 0.0.0.0
nat (management) 0 0.0.0.0 0.0.0.0
static (External,Internal) 192.168.0.x 64.179.10.29 netmask 255.255.255.255
static (External,Internal) 192.168.0.x 64.179.10.32 netmask 255.255.255.255
access-group Internal_access_in in interface Internal
access-group External_access_in in interface External
access-group External_access_out out interface External
route External 0.0.0.0 0.0.0.0 63.179.53.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.0.x 255.255.255.255 Internal
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd lease 3600
dhcpd ping_timeout 50
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
Cryptochecksum:xxx
: end
15 Replies 15
That's backwards.
The first host or network is always the source, the second is the destination.
Since the access list is applied into the outside interface, people from the internet will be the source and your mail server is the destination.
access-list External_access_in extended permit tcp eq
In the statment below
= any
= host 64.179.53.30
= smtp
access-list External_access_in extended permit tcp any host 64.179.53.30 eq smtp
