Changed IP of outside and inside interfaces and rules.... having issues.....
Scott
Had configuration working in LAB. . Just changed IP’s for new test….. now we cannot get into ASDM and access-list are dropping or packets… not sure what is wrong. Below is the configuration and the packet trace. Any help would be GREATLY appreciated.
: Saved
: Serial Number: FCH204473W4
: Hardware:   ASA5525, 8192 MB RAM, CPU Lynnfield 2394 MHz, 1 CPU (4 cores)
ASA Version 9.7(1)
hostname ciscoasa
enable password sBKYBaafCSjFcId5 encrypted
names
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 10.180.201.60 255.255.255.248
interface GigabitEthernet0/1
shutdown
nameif inside
security-level 100
interface GigabitEthernet0/2
nameif Delta
security-level 100
ip address 10.180.206.225 255.255.255.224
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/6
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/7
shutdown
no nameif
no security-level
no ip address
interface Management0/0
management-only
no nameif
no security-level
no ip address
boot system disk0:/asa971-smp-k8.bin
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network RDP-connection
host 10.180.206.240
object service RDP-SERVICE
service tcp destination eq 3389
object service RDP-service
service tcp source eq 3389
object network OPC-connection
host 10.180.206.240
object service OPC-SERVICE
service tcp destination eq 135
access-list 101 extended permit tcp any any eq 21379
access-list 101 extended permit icmp any any echo
access-list 101 extended permit icmp any any echo-reply
access-list 101 extended permit icmp any any unreachable
access-list 101 extended permit icmp any any time-exceeded
access-list 101 extended permit icmp any any traceroute
access-list 101 extended permit ip 10.180.206.0 255.255.255.224 10.180.201.0 255.255.255.248
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu Delta 1500
no failover
no monitor-interface service-module
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-771.bin
asdm history enable
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 16384
nat (Delta,outside) source static RDP-connection interface service any RDP-service
nat (outside,Delta) source static any any no-proxy-arp
nat (any,outside) dynamic interface
access-group 101 in interface outside
access-group 101 out interface outside
access-group 101 in interface Delta
access-group 101 out interface Delta
router rip
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
user-identity default-domain LOCAL
http server enable
http 10.180.206.0 255.255.255.224 Delta
http 10.180.201.0 255.255.255.248 outside
no snmp-server location
no snmp-server contact
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet 10.180.206.0 255.255.255.224 Delta
telnet timeout 5
no ssh stricthostkeycheck
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
threat-detection basic-threat
threat-detection scanning-threat
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
dynamic-access-policy-record DfltAccessPolicy
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
  no tcp-inspection
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
class class-default
  user-statistics accounting
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
hpm topN enable
Cryptochecksum:9a8da34dc8cb18c1782f9ffbcd77f2d2
: end
Packet Trace:
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
Forward Flow based lookup yields rule:
in  id=0x2aaac7ed22d0, priority=1, domain=permit, deny=false
        hits=412, user_data=0x0, cs_id=0x0, l3_type=0x8
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0100.0000.0000
        input_ifc=outside, output_ifc=any
Phase: 2
Type: ROUTE-LOOKUP
Subtype: Resolve Egress Interface
Result: ALLOW
Config:
found next-hop 10.180.206.240 using egress ifc  Delta
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
in  id=0x2aaac7977990, priority=501, domain=permit, deny=true
        hits=1, user_data=0x7, cs_id=0x0, reverse, flags=0x0, protocol=0
        src ip/id=10.180.201.60, mask=255.255.255.255, port=0, tag=any
        dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any, dscp=0x0
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: Delta
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Rahul Govindan
Not sure what source you are trying this from but your http access on the Delta interface is limited to source 10.180.206.0/27.
This is different from your Delta interface subnet 10.180.206.224/27.
You do not seem to have a static route to 10.180.206.0/27, so I am assuming that the http command address is wrong.
Rahul Govindan
