Cisco Asa Failover Fail/ Interface Up but does not Sync
jtapia0011
Visitor
Hello Guys, I'd appreciate it if you'd help me out.
I have two firewalls, a primary and a secondary in failover mode, 5 days ago I failed the primary and the secondary took the role of active, so far so good.
The problem is that the primary/standby does not synchronize the settings and neither does its failover status.
As a note I want to let you know that curiously the ips of the failover interfaces pinging between them, which is weird because the interface says fail but I can ping between them.
Status from active and working firewall
Failover On
Failover unit Secondary
Failover LAN Interface: failint Ethernet0/3 (up)
Unit Poll frequency 1 seconds, holdtime 15 seconds
Interface Poll frequency 5 seconds, holdtime 25 seconds
Interface Policy 1
Monitored Interfaces 6 of 110 maximum
Version: Ours 8.2(5)59, Mate 8.2(5)59
Last Failover at: 20:18:15 CHILE Jun 4 2020
This host: Secondary - Active
Active time: 511245 (sec)
slot 0: ASA5510 hw/sw rev (2.0/8.2(5)59) status (Up Sys)
Interface inside (A.B.C.D): Normal (Waiting)
Interface dmz (A.B.C.D): Normal (Waiting)
Interface dmz2 (A.B.C.D)): Normal (Not-Monitored)
Interface New_DMZ (A.B.C.D)): Normal (Waiting)
Interface LAN-WESTFIRE (A.B.C.D): Unknown (Waiting)
Interface management (A.B.C.D)): Link Down (Waiting)
Interface outside (A.B.C.D): Normal
slot 1: ASA-SSM-10 hw/sw rev (1.0/) status (Unresponsive/Up)
Other host: Primary - Failed
Active time: 0 (sec)
Interface inside (A.B.C.D)): Failed (Waiting)
Interface dmz (A.B.C.D)): Failed (Waiting)
Interface New_DMZ (A.B.C.D)): Failed (Waiting)
Interface LAN-WESTFIRE (A.B.C.D)): Unknown (Waiting)
Interface management (0.0.0.0): Link Down (Waiting)
Interface outside (A.B.C.D)): Normal
slot 1: ASA-SSM-10 hw/sw rev (1.0/6.0(4)E1) status (Up/Up)
IPS, 6.0(4)E1, Up
Stateful Failover Logical Update Statistics
Link : Unconfigured.
# show failover state
State Last Failure Reason Date/Time
This host - Secondary
Active None
Other host - Primary
Failed Ifc Failure 18:10:24 CHILE Jun 10 2020
inside: Failed
dmz: Failed
New_DMZ: Failed
====Configuration State===
Sync Done
Sync Done - STANDBY
====Communication State===
Mac set
show failover interface ( I CAN PING THEM)
interface failint Ethernet0/3
System IP Address: 1.1.1.4 255.255.255.248
My IP Address : 1.1.1.5
Other IP Address : 1.1.1.4
Standby Ready Just Active Other unit wants me Active
Just Active Active Drain Other unit wants me Active
Active Drain Active Applying Config Other unit wants me Active
Active Applying Config Active Config Applied Other unit wants me Active
Active Config Applied Active Other unit wants me Active
Sheraz.Salim
Seems likely you have a layer 1 or 2 issue. check your switch in between these two firewalls. Interface inside (A.B.C.D)): Failed (Waiting)   Interface dmz (A.B.C.D)): Failed (Waiting)  Interface New_DMZ (A.B.C.D)): Failed (Waiting)  are showing as Failed.
Failover On
Interface Policy 1
IPS, 6.0(4)E1, Up
please do not forget to rate.
You mean check Failover interface cable port and switch right?
Att
your primary firewall have some issue with interfaces check layer 1 and 2 connectivity.
