Cisco ASA Multiple Context using same outside public IP address
johnlloyd_13
Level 11
Level 11
hi,
i'm going to separate internal/core and external/customer IPSec VPN into separate context, i.e. context A is for internal/core and context B for external/customer. both are using the same outside public ip address.
can i use the same outside public ip in both ASA context so i don't need to re-ip the remote VPN peer?
Hi @johnlloyd_13 no I don't think its possible to share the IP address, you can certainly share the interfaces between contexts.
Marvin Rhoads
Confirming @Rob Ingram 's belief - you cannot share IP addresses among interfaces in different contexts.
I think you can put router Infront of ASA and use multi context
