Cisco Pix 515 E - Need help
lgoodman123
Community Member
Our internet goes down after being up for about an hour. To get it back, I power off and power back on our Cisco Pix 515 E. Can anyone give me some guidance as to what the problem might be?
Thank you in advance.
noran01
Level 5
Level 5
Check the logs first. If they are empty be sure to enable logging for errors and warnings.
What kind of upstream connection? static ip or dhcp? I need more information to properly troubleshoot
How do I get to the log files?
We have static IP.
We have static IP.
logging enable
logging buffered notifications" (you can also use the "warnings" level if you
want fewer messages).
