ciscoworks LMS 2.2 layer 2 trace problem
munyaradzi
Community Member
i have a 3745 (seed device) connected to a 2611xm via a 2950 switch but the ani server cannot discover the 2611xm or even properly recognize the 2950 switch. i have configured the required snmp parameters and cdp is enabled on all devices. i can also ping the 2950 and 2611xm from the ciscoworks server.
do i need special configs on the 2950 for the ani server to discover the 2611xm router?
Marvin Rhoads
To troubleshoot, go into the respective devices and execute "show cdp neighbors" commands.
If the devices all see each other as neighbors, the problem is in CW's interaction with the devices. If that is the case, make sure each device's credentials are allowing CW to correctly query it.
If not, then fix the cdp interaction on the devices and rediscover and then recheck CW's network view.
Hope this helps. Please rate helpful posts.
