DHCP problem on NAC, v4.0.5
joshua
I am using NAC as In-Band mode on v4.0.5.
Whenever I add a new vlan on it, existing users don't get IP addresses from DHCP server which is on trusted network with ip helper-address, unless I delete current vlan mappings and add them back. Any idea?
oabduo983
Make sure you have an IP address on your managed subnet that is free with the vlan beng the corresponding L3 trusted vlans...
Plz rate this post if it helps
regards,
