Difference between Cisco Firewall Singlemode/ Multimode and single/Multiple Context
Nexus19
Visitor
Please let me know if there is a difference between Singlemode and Multimode in ASA firewall.
Also, please let me know the difference between context and mode.
gbekmezi-DD
Level 9
Level 9
There is no such thing as “singlemode” or “multimode” in the firewall. Those are traditionally used to refer to fiber media types. Single context mode and multi context mode are explained here:
https://www.cisco.com/c/en/us/td/docs/security/asa/asa90/configuration/guide/asa_90_cli_config/ha_contexts.html#91108
Excerpt:
You can partition a single ASA into multiple virtual devices, known as security contexts. Each context acts as an independent device, with its own security policy, interfaces, and administrators. Multiple contexts are similar to having multiple standalone devices.
Thank you  gbekmezi.
venkat_n7
Level 4
Level 4
Multi context - is a great feature available for all current firewalls. to explain it takes time but in short i say -- multi context is used to split physical firewall into multiple virtual firewalls and assign rules based on context, this is mainly used in Service providers environment.
below i would provide links that has detailed information  !!!
https://www.cisco.com/c/en/us/td/docs/security/asa/asa96/configuration/general/asa-96-general-config/ha-contexts.pdf
https://networkdirection.net/articles/asa/asamultiplecontextmode/
Hope this helps. Please rate the reply and support.
Please rate comments and support
with regards,
Venkat
Thank you Venkat
