Difference between static NAT and a static route - ASA 5506-X
marcos500
It seems that there isn't a simple explanation of this when you google it...
I have seen hundreds of articles and forum entries explaining the difference between static NAT, dynamic NAT and PAT and I think I understand the difference between them. However, when would you use static route vs a static NAT ?
From what I understand, routes are used for traffic that never changes i.e. a subnet that is always bound to a certain interface address.
Can anyone shed some light on this please? I am using an ASA 5506-X.
Many thanks
They are two different things so it is not a case of one being preferable over the other.
NAT is used, as Vibhor says, to translate IPs.
Static routes are used to tell the ASA how to reach remote networks so you would usually have at least a default static route pointing to the ISP router and perhaps static routes for internal networks if there is a L3 device internally routing for your vlans.
So there aren't really any cases of where you would use one or the other to achieve the same thing because they don't do the same thing.
Jon
Vibhor Amrodia
I think to explain it in a simple and straight forward way ,  Static route is a route created on the ASA device to help the ASA device reach the specific destination.
When we talk about the Static NAT , it is used to translate the IP address of a device on the ASA device.
So , these are different features used on the ASA device.
Thanks and Regards,
Vibhor Amrodia
Tanks Vibhor.
Can you or anyone give me examples as to when a static rout would be preferable or even necessary? There must be specific circumstances in which a static route is recommended over a static NAT rule.
Jon
Okay I get that they are two different things. However, does that mean that when routing from a local network to a wider network, the IP address will stay the same? Will computers on the wider network see 192.168.***.*** as the computer's IP address or 10.16.***.*** as the computer's IP address if the switch does not have NAT?
