Failover traffic sync problem
souvik.mazumdar
Community Member
If I permit udp traffic specifically in nat0 statement facing problem with configuration sync in failover.
Instead if I permit tcp or ip in nat0 statement every thing works fine.
What might be the problem?
Regards..
vmoopeung
Level 11
Level 11
You may try using the "nat-control" statement. The nat-control command on the PIX/ASA specifies that all traffic through the firewall must have a specific translation entry (nat statement with a matching global or a static statement) for that traffic to pass through the firewall.
