Firepower HA 2 subnets problem
cm
Level 3
Level 3
Hi All
I have 2 Firepower FTD (2130 models) in HA (high availabilty)mode working well in routed Mode. Its working using ONE  protected subnet eg 98.x.x.0/24 for  my servers. My servers are reachable from the outside using Public Addresses etc. BUT I have requirement to add a SECOND  Subnet eg 49.x.x.0/24 on the same HA pair. is that possible. Logically this leans to BGP to advertise internal Networks.  Any Examples or case Studies. So my Current setup below looks something like this ;
98.x.x.3 - 12( Protected Servers)--------98.x.x.1-2(Gw) [{Inside} HA -FTD(2 ftd) {Ouside} ] 69.x.x.1-2--- Static >---69.x.x.250[ Router-ISP ] (WORKING )
REQUIRED
98.x.x.0/24 and 49.x.x.0/24( Protected Servers)--------98.x.x.1-2(Gw) [{Inside} HA -FTD(2 ftd) {Ouside} ] 69.x.x.1-2--- Static >---69.x.x.250 [Router-ISP ]
Please Assist
We managed to get working using IGP in our case it was OSPF used to advertise routes. I had made a mistake saying Subinterfaces dont work... It was just my wrong interpretation. Sub interfaces dont work on the failover link only.
but config subinterface in FTD can solve issue this make FTD have one subinterface for each subnet.
Unfortunately you cannot use subinterfaces in high availability mode.
So glad your issue solve.
Good luck freind
