Firepower Management still says: Interface 'DataPlaneInterface0' is not receiving any traffic
roesch4alc
Level 4
Level 4
Im still stuck with the message, that you can read in the topic. I think my setup should work, because I created an acl, that redirects traffic to the SFR Modul. But it looks like, that FMC is not receiving andthing. In the moment there is not much data traversing the firewall, but there is traffic.
Im wondering, that "sh service-policy sfr" doesn´t show any hits! Any ideas? What can I do? I already rebootet the sfr modules.
Global policy:+
Service-policy: global_policy
Class-map: sfr
SFR: card status Up, mode fail-open
packet input 0, packet output 0, drop 0, reset-drop 0
Another question: Is it a problem to activate "enable monitor only" mode in a routed firewall mode? I would like to start with this setting, to be sure, that no datastreams will be modified in the first step.
Best regards
Sebastian
15 Replies 15
Farhan Mohamed
I feel there is issue with the updated version of this stuff, I would recommend you go with the update for ASA and the believe that will help you out.
