FireSIGHT System generates connection events although logging is disabled
Nazmul Rajib
Although all Connection Logging options are disabled in an Access Control policy, my Sourcefire FireSIGHT System still generates a Connection Event.
Nazmul Rajib
Reason
A Sourcefire FireSIGHT System generates a Connection Event when an Intrusion Event is generated. A Connection Event is generated on the web interface of the Sourcefire FireSIGHT Management Center for the following reasons:
  • Intrusion Block
  • Intrusion Monitor
Solution
If this feature is undesired, it may be disabled from the shell using the following command:
> configure log-ips-connection disable
