FPR 1120 reimage problem
lmoceze
Hey there,
I try to reimage my FPR 1120 box from 6.x to 7.2.5, however I am facing the following problem:
xxx> show version
----------------------[ xxx ]-----------------------
Model : Cisco Firepower 1120 Threat Defense (78) Version 6.4.0 (Build 102)
xxx(local-mgmt)# format everything
All configuration and bootable images will be lost.
Do you still want to format? (yes/no):yes
rommon 13 > tftp -b
Ethernet init success
Enable boot bundle: tftp_reqsize = 268435456
IMAGE: cisco-ftd-fp1k.7.2.5-208.SPA
link up
Receiving cisco-ftd-fp1k.7.2.5-208.SPA from (...) !!!
Overall timeout.
File reception completed.
Boot buffer bigbuf=640ff498
Boot image size = 199115728 (0xbde43d0) bytes
[image size] 199115728
Failed to validate digital signature in Primary key Storage !!
Failed to validate digital signature in Backup key Storage !!
+------------------------- FAILURE ---------------------------------+
| LFBFF signature authentication failed !!! |
Incorrect installer image for this platform !!
Failed to Free memory block at address 0x00000000640ff498
(...) means that I cut some parts of the output.
However the Incorrect installer image for this platform !! seems to be a pretty straight forward message, as I understood, the SPA is the fresh install package, not the ral.tar. So im not sure what Im missing here.
Did anyone faced this issue too?
Thanks a lot!
Hello All,
The problem was that more than 0 packets got lost during transit, so the image was incorrect.
Moral of the story: use USB or dont put your life on TFTP + Internet
Mark Elsen
 - Ref : https://www.cisco.com/c/en/us/td/docs/security/secure-firewall/release-notes/threat-defense/720/threat-defense-release-notes-72.html#r_ftd-upgrade-path
           Check Table 17.  it looks like you can not go directly from 6.4 to 7.2.5 ,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Hi M.!
Thanks for the reply!
However, I have did:
 As of my understanding, it should be an "empty" box, does the upgrade path still matters?
Thanks a lot!
lmoceze
Hey there,
It turns out that the MD5 of the image on the Cisco site and the MD5 of the image copied is not the same (probably got lost on the way due to TFTP copy + internet)  so I think that is the reason. I will do it another way, will keep you posted.
Hello All,
