FTD upgrade problem
wanatkinson
Frequent Visitor
Frequent Visitor
I recently installed a FMCv on VMware (v6.6.1) and 2x 2110 FTD units which came with 6.3.0.5. I expected updates for the 2110s to appear in the FMC so I could upgrade to 6.6.1. It keeps saying "no updates available".  FDB and GeoDB updates are working, and I can telnet to support.sourcefire.com on port 443.
Does anyone have an explanation or advice on this?
Smart licensing is in place and showing as connected in FMC and used in the licensing manager portal.
@wanatkinson
The FMC will only display minor updates, not a major update (6.6.x). You'll need to download the upgrade package from the cisco website and upload to the FMC.
@wanatkinson
rhuysmans
Level 4
Level 4
I would just download the files from Cisco and then upload them manually from your PC.
