Help creating a NAT rule from ASA to FTD using FPMC
justinarendt
I am trying to figure out how to replicate an existing configuration for NAT from my ASA to a FTD using FPMC to configure the device (5506-X).  I have attached a screenshot of what works now in the ASA.
I want to be able to do port natting from the outside interface on a per port basis using my single EXT IP on the outside interface.
All traffic inside, and outbound - nat to EXT IP
Inside ServerA Port 1111UDP - Nat to EXT IP 1111
Inside ServerA Port 1111TCP - Nat to EXT IP 1111
Inside ServerB Port 8080TCP - Nat to EXT IP 8080
Basically I want to map multiple internal IP's with different services to be allowed inbound from a single EXT IP on the outside.
I can't seem to figure this out on the FTD, but it works great with ASA.
Any help would be much appreciated.
Cheers,
Justin
s7pizzi
Hi Justin,
I have the same problem. How did you solve it?
yogdhanu
if you have ASA and migrating to FTD, you can try migration tool to convert the config.
https://www.cisco.com/c/en/us/td/docs/security/firepower/620/asa2ftd-migration/asa2ftd-migration-guide-620/asa2ftd_migration_procedure.html
You can try dynamic NAT on FMC for FTD.
Hope it helps,
Yogesh
