IDSMC 1-2 Patch installation problem
pfligman
Community Member
I have just updated to VMS 2.2 and IDSMC 1.2 on Windows 2k SP3 and want to install all three latest patches available. When I go to install the patches I get the follwing warning message:
This Point Patch is not intended for this version of idsmdc. If you go ahead and Install this patch some functionality of idsmdc might malfunction.Please confirm with TAC before applying the patch.
Do you wish to continue (Y/N) [Y] :
Is it ok to go ahead and install patches (which are for version 1.2 IDSMC) as I am sure I am on IDS MC 1.2? The 3 patch numbers are
CSCsa014622, CSCeb566711 & CSCeb696471.
Peter
b.speltz
Level 8
Level 8
These are IDS MC 1.2 patches. You can ignore this warning message and go ahead with installation of patches.
Installed patches ok, cheers.
