IPS network Module, need help!!!
NAVIN PARWAL
Level 7
Level 7
Folks,
I recently installed IPS network module in my 3662 router. I am having problems making the IPS log anything.
When i access the web interface of the IPS, i see only 1 interface available under virtual sensor, the interface is fast 0/1. and the media type it shows is Backplain.
I am confused, i thought that fast 0/1 on the IPS network module was the management interface??? on the IPS?
Why don't i see another interface that is connected to the backplain of the switch???
Many thanks
marcabal
There are 2 interfaces on the NM-CIDS.
In version 5.0 they are called:
FastEthernet0/0 and FastEthernet0/1
FastEthernet0/0 is the external copper interface that you can plug a cable in to. It is the command and control port for managing the NM-CIDS. It can not be used for monitoring (can not be applied to the virtual sensor)
FastEthernet0/1 is the backplane interface. It receives packets from the router for monitoring. This is the interface that should be applied to the virtual sensor.
