logging on ACLs - problem with deny ACEs
johanhofmans
I discovered that recently our FWSM does not want to log deny-flows any more.
Whenever I want a certain ACE to be logged, I enable the logging with the alert level - and it gets Syslogged.
Configuration used:
BE01NF31/UNIVEG# sh run log
logging enable
logging timestamp
logging list ErLst level alerts
logging list ErLst message 106100
logging buffer-size 16384
logging trap ErLst
logging asdm ErLst
logging host FW_Ext BE01S514
logging permit-hostdown
logging class config trap warnings
logging class ip trap alerts
Whenever I log a 'permit' ACE, it works fine, but when I want to log a 'deny' ACE, nothing is sent to the Syslog server.
What can cause this behaviour? What can I check?
Thanks !!
Jennifer Halim
There is a possibility that you might be hitting the maximum number of ACL log deny-flows via syslog message# 106101:
http://www.cisco.com/en/US/docs/security/fwsm/fwsm32/system/message/logmsgs.html#wp1727742
However since you are only sending syslog message# 106100 to your syslog server, you are not seeing the other syslog messages that might give you an explaination on why you are not seeing the deny logs.
Hope that helps.
