MPF (Inspection Engine)
arshad_cisco86
Community Member
Hi All,
what about inspection,suppose we made two policy and apply on the same interface .
Q.A)one of two policy will work?
access-list 101 permit ip host 1.1.1.1 host 2.2.2.2
class-map drop_class
 match access-list 101
policy-map drop_policy
 class drop_class
    drop
 class drop_class
    inspect
Arshad Ayub
Rishabh Seth
Level 10
Level 10
Hi Arshad,
As per my understanding the ASA should evaluate the service policy in top to down fashion and stop evaluation after hitting the matching rule.
You can also use show service policy flowcommand to check the service policy that will be evaluated for specific traffic.
Refer this link for syntax: http://www.cisco.com/c/en/us/td/docs/security/asa/asa-command-reference/S/cmdref3/s12.html#pgfId-1336197
Hope it helps.
Rishabh Seth
Rishabh Seth
Level 10
Level 10
Hi Arshad,
Hope it helps.
Rishabh Seth
