need to turn off IDS normalization engine.
syjeon
Level 5
Level 5
Hi all.
I would like to know how can we turn off cisco ids nomalization engine? Is it complicated one or not?
We have some issue when we enable cisco nomalization engine on ids which is inline mode. some of assymetric traffic will be dropped.
So, we are going to disable cisco nomalization, now.
please give us any advice for us.
Thanks you.
Justin Teixeira
Level 4
Level 4
Hi Syjeon,
    You can set the normalizer mode for the virtual sensor in question to "Asymmetric Mode Protection" to relax the TCP normalization if the sensor is inspecting asymmetric traffic:
http://www.cisco.com/en/US/docs/security/ips/7.0/configuration/guide/cli/cli_virtual_sensors.html#wp1034136
You'll want to change the "inline-TCP-evasion-protection-mode" option from "strict" to "asymmetric" for each of the virtual sensors seeing asymmetric traffic.
-Justin
Justin Teixeira
Level 4
Level 4
Hi Syjeon,
-Justin
