Overlapping nat rule problem
egthkaa20060417
The following is the nat rules for my asa5510
static (LAN,WAN) tcp PCCW_Pri_SMTP ftp LAN_MS02 ftp netmask 255.255.255.255
static (LAN,WAN) tcp PCCW_Pri_SMTP ssh LAN_MS02 ssh netmask 255.255.255.255
static (LAN,WAN) tcp PCCW_Pri_SMTP www LAN_MS02 www netmask 255.255.255.255
static (LAN,WAN) tcp PCCW_Sec_SMTP 2525 LAN_MS02 smtp netmask 255.255.255.255
static (DMZ,WAN) tcp PCCW_Sec_Webmail https DMZ_MS01 https netmask 255.255.255.255
static (DMZ,WAN) tcp PCCW_Sec_SMTP ftp DMZ_MS01 ftp netmask 255.255.255.255
static (DMZ,WAN) tcp PCCW_Sec_SMTP ssh DMZ_MS01 ssh netmask 255.255.255.255
static (DMZ,WAN) tcp PCCW_Sec_SMTP 27 DMZ_MS01 27 netmask 255.255.255.255
static (DMZ,WAN) tcp PCCW_Pri_SMTP smtp DMZ_IronPort_2 smtp netmask 255.255.255.255
static (DMZ,WAN) tcp PCCW_FTP ftp DMZ_FTP ftp netmask 255.255.255.255
static (DMZ,WAN) tcp PCCW_Sec_SMTP smtp DMZ_MS01 smtp netmask 255.255.255.255
static (LAN,DMZ) 192.168.10.0 192.168.10.0 netmask 255.255.255.0
static (DMZ,LAN) 172.16.0.0 172.16.0.0 netmask 255.255.255.0
static (LAN,WAN) PCCW_Sec_SMTP LAN_MS02 netmask 255.255.255.255
When I tried to change the static rule "static (DMZ,WAN) tcp PCCW_Sec_SMTP smtp DMZ_MS01 smtp netmask 255.255.255.255 " to "static (DMZ,WAN) tcp PCCW_Sec_SMTP smtp DMZ_IronPort_2 smtp netmask 255.255.255.255". I got the overlapping of nat error. How do I fix it? Thanks.
25 Replies 25
Hi Steven,
This error is expected because the ASA cannot translate the same public IP and port to different internal hosts. Think about it this way:
static (DMZ,WAN) tcp PCCW_Sec_SMTP smtp DMZ_IronPort smtp netmask 255.255.255.255
If a packet enters the WAN interface destined to PCCW_Sec_SMTP on TCP port 25, what should the destination address be translated to? Those rules are saying it should be translated to *both* DMZ_IronPort and DMZ_MS01, which is not possible. It can only be translated to 1 internal host.
As an alternative, you would need to use a different public IP address or change one of the mapped ports, such as:
static (DMZ,WAN) tcp ALT_PCCW_SMTP smtp DMZ_MS01 smtp netmask 255.255.255.255
or
static (DMZ,WAN) tcp PCCW_Sec_SMTP 2525 DMZ_MS01 smtp netmask 255.255.255.255
Hope that helps.
-Mike
Hi Mike,
Originally, the existing rule is this
and I want to change it to
and I got the overlapping error with the rule: "static (LAN,WAN) PCCW_Sec_SMTP LAN_MS02 netmask 255.255.255.255"
Hope that it can clarify my problem. Thanks.
Hi Steven,
You are using overlapping public ip address. You can't use the same ip address to configure static 1:1. You can configure static port address redirection on different ports using the same public ip address.
So currently the following 2 static NAT will overlap:
So the 2nd line is 1:1 static NAT and you can't reuse the same public ip address after you configure the static 1:1 NAT.
However, if you change the 2nd line to be static port address redirection on other ports than smtp, then it will work.
Example:
static (LAN,WAN) tcp PCCW_Sec_SMTP 3000 LAN_MS02 3000 netmask 255.255.255.255
(port 3000 is just an example, and you would need to change it to the port that you like access on for LAN_MS02 server accordingly).
Hi Jennifer,
Then why the other rules e.g static (DMZ,WAN) tcp PCCW_Sec_SMTP ftp DMZ_MS01 ftp netmask 255.255.255.255
will not cause the overlapping problem? Thanks.
Because it is static PAT, not static 1:1 NAT.
Difference is you are statically NATing 1 ip address to another ip address for static 1:1 NAT (and this means it includes all ports), while static PAT, you are NATing the ip address only base on 1 port.
The reason why it doesn't overlap with this:
is because the port is different. The above line is on port 21 (ftp), and the other one is on port 25 (smtp).
Hi Jennifer,
Sorry for my stupid question, according to the config
1.static (DMZ,WAN) tcp PCCW_Sec_SMTP ftp DMZ_MS01 ftp netmask 255.255.255.255
2.static (DMZ,WAN) tcp PCCW_Sec_SMTP smtp DMZ_IronPort smtp netmask 255.255.255.255
3.static (LAN,WAN) PCCW_Sec_SMTP LAN_MS02 netmask 255.255.255.255
Rule 1 is a Static PAT, at the same time rule 2 is also a static PAT. Why rule 1 will not overlap with rule 3 while rule 2 does? Thanks.
It will overlap, and you shouldn't really configure rule# 3.
The reason why it will overlap is because, if traffic is sent towards PCCW_Sec_SMTP (public ip address), and you have static 1:1 configured, it has no way in knowing which private server it should translate the ip address back to if you don't specify the actual port. As advised earlier, if you configure static 1:1 NAT, you can't share the public ip address. You can only share the public ip address if you configure static PAT with different ports.
Do you mean that rule 1 also overlap with rule 3?
Yes... Rule# 1 and Rule#3 also overlaps.
The reason why you can enter the command in before is probably you configure rule# 1 first, then you enter rule# 3. Eventhough it doesn't give you an error message of them being overlapping, they do overlap and it is not a supported configuration.
So you remove rule# 3, then enter in rule# 2, and then reenter rule# 3, it will not give you any error message in regards to overlapping. In theory, it should give you the error, and it's probably a software bug that it doesn't give you the error message when it overlaps.
In summary, you can't configure Rule# 3, if you are already using the same ip address for static PAT.
Hi Jennifer.
You are right. I tried to change the Rule 3 from static NAT to static PAT. It prompt me the error about overlapping. I need to remove this rule to make it work. Thanks.
Thanks for the update.
Please kindly mark the post as answered if you have no further question. Thank you.
