pinging ASAv9.3 outside interface using gns3
oforomar78
Visitor
Hi friends ,
This is Umar here , I am new in CCNA security and self learner . I am configuring firewall in gns3 image is ASAv 9.3(200) and ASDM is 7.5.1 . i am using mostly command line . Problem is Host1 can ping gig0 of ASA1-1 but can not ping Gig1 of ASA1-1 and ASA1-1 can ping every where
any help will be appreciated
It's by design of the ASA that you can only access/ping the nearest interface to the host. That means Host1 can only ping Gig0, a host connected to Sw2 can only ping Gig1 but not Gig0.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
