PIX 506 - problem disabling Mailguard
hueylee99
Community Member
On my PIX506, I tried entering the "no fixup protocol smtp 25" on the CLI, but it fails to remove the fixup statement and tells me to "type help or ? for..." instead. Any advice on the syntax or knowledge of any dependencies is greatly appreciated.
-HL
s.gando
Community Member
You must enter "config terminal" before the "no fixup" command.
Thanks S.Gando! First time using a PIX so I'm still treading through the CLI syntax.
