PIX EZVPN Phase 1 Problem
thethmon
I am having trouble getting past phase 1 with my PIX501 running 6.3(3). Below is the log from the VPN3060 concentrator (4.04a) showing an error. Unfortunately, I cannot find anything on CCO for what this error and associated flags mean.
59586 02/13/2004 10:19:40.500 SEV=7 IKEDBG/65 RPT=165 200.78.65.18
Group [Default]
IKE AM Responder FSM error history (struct &0xfbfb3c8)
<state>, <event>:
AM_DONE, EV_ERROR_CONT
AM_DONE, EV_ERROR
AM_WAIT_MSG3, EV_TIMEOUT
AM_WAIT_MSG3, NullEvent
59591 02/13/2004 10:19:40.500 SEV=9 IKEDBG/0 RPT=4113 200.78.65.18
Group [Default]
IKE SA AM:fa8b7efd terminating:
flags 0x0100c001, refcnt 0, tuncnt 0
rmarchant
Community Member
I am currently having the same problem. Did you find a resolution, to the Phase 1 negotiation issue with EZVPN.
If I remember correctly, I had to re-enter the group/pwd and username/pwd pairs and it worked. For some reason after a reboot, the passwords became corrupted.
