Problem deploy cisco FMC
e.daurembekov
Community Member
Please help, after update Snort Rule 2021-09-22-001-vrt
Log
=========SNORT APPLY=========
Sep 24 03:48:59 Finished Export for AccessControl
Sep 24 03:48:59 Starting Export for ARC
Sep 24 03:48:59 Finished Export for ARC
Sep 24 03:48:59 Starting Export for Beaker
Sep 24 03:48:59 Finished Export for Beaker
Sep 24 03:48:59 Starting Export for Geolocation
Sep 24 03:48:59 Finished Export for Geolocation
Sep 24 03:48:59 Starting Export for Onbox
Sep 24 03:48:59 Finished Export for Onbox
Sep 24 03:48:59 Starting Export for SFDataCorrelator
Sep 24 03:48:59 Finished Export for SFDataCorrelator
Sep 24 03:48:59 Starting Export for SFTunnel
Sep 24 03:48:59 Finished Export for SFTunnel
Sep 24 03:48:59 Starting Export for SensorClustering
Sep 24 03:48:59 Finished Export for SensorClustering
Sep 24 03:48:59 Starting Export for StateSharing
Sep 24 03:48:59 Finished Export for StateSharing
Sep 24 03:48:59 Starting Export for Snort
Sep 24 03:48:59 copytree failed: (/ngfw/usr/bin/rsync -a -L -K -O --no-owner --no-group --no-perms --safe-links /ngfw/var/cisco/deploy/sandbox/modulepack-pkg/so_rules/850cbf45fbf37966f62bc41780c050c3 /ngfw/var/cisco/deploy/sandbox/exported-files/var/sf/detection_engines/6e9f3a88-fb89-11e9-b0e5-212d508a897f/so_rules) with rcode 23
stdout:
stderr: rsync: link_stat "/ngfw/var/cisco/deploy/sandbox/modulepack-pkg/so_rules/850cbf45fbf37966f62bc41780c050c3" failed: No such file or directory (2)
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1189) [sender=3.1.3]
========= CLI APPLY =========
========= INFRASTRUCTURE MESSAGES =========
errorString : Sep 24 03:48:59 Finished Export for AccessControl
stdout:
PrepareExportAppConfigFailed: : Please refer action_queue.log file for more details;
errorCode : device_failure_configuration
DeploymentException : {"errStackTrace":{"-file":"/ngfw/usr/local/sf/bin/policy_apply.pl","-stacktrace":"Sep 24 03:48:59 copytree failed: (/ngfw/usr/bin/rsync -a -L -K -O --no-owner --no-group --no-perms --safe-links /ngfw/var/cisco/deploy/sandbox/modulepack-pkg/so_rules/850cbf45fbf37966f62bc41780c050c3 /ngfw/var/cisco/deploy/sandbox/exported-files/var/sf/detection_engines/6e9f3a88-fb89-11e9-b0e5-212d508a897f/so_rules) with rcode 23\nstdout: \nstderr: rsync: link_stat \"/ngfw/var/cisco/deploy/sandbox/modulepack-pkg/so_rules/850cbf45fbf37966f62bc41780c050c3\" failed: No such file or directory (2)\nrsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1189) [sender=3.1.3]\n\n at /ngfw/usr/local/sf/bin/policy_apply.pl line 195\n","-text":"Sep 24 03:49:05 Sep 24 03:48:59 copytree failed: (/ngfw/usr/bin/rsync -a -L -K -O --no-owner --no-group --no-perms --safe-links /ngfw/var/cisco/deploy/sandbox/modulepack-pkg/so_rules/850cbf45fbf37966f62bc41780c050c3 /ngfw/var/cisco/deploy/sandbox/exported-files/var/sf/detection_engines/6e9f3a88-fb89-11e9-b0e5-212d508a897f/so_rules) with rcode 23\nstdout: \nstderr: rsync: link_stat \"/ngfw/var/cisco/deploy/sandbox/modulepack-pkg/so_rules/850cbf45fbf37966f62bc41780c050c3\" failed: No such file or directory (2)\nrsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1189) [sender=3.1.3]\n\n\n","-package":"main","-line":195},"status":{"error_message":"Sep 24 03:48:59 copytree failed: (/ngfw/usr/bin/rsync -a -L -K -O --no-owner --no-group --no-perms --safe-links /ngfw/var/cisco/deploy/sandbox/modulepack-pkg/so_rules/850cbf45fbf37966f62bc41780c050c3 /ngfw/var/cisco/deploy/sandbox/exported-files/var/sf/detection_engines/6e9f3a88-fb89-11e9-b0e5-212d508a897f/so_rules) with rcode 23\nstdout: \nstderr: rsync: link_stat \"/ngfw/var/cisco/deploy/sandbox/modulepack-pkg/so_rules/850cbf45fbf37966f62bc41780c050c3\" failed: No such file or directory (2)\nrsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1189) [sender=3.1.3]\n\n","device_error":{"csmArgsList":[{"value":"Sep 24 03:48:59 copytree failed: (/ngfw/usr/bin/rsync -a -L -K -O --no-owner --no-group --no-perms --safe-links /ngfw/var/cisco/deploy/sandbox/modulepack-pkg/so_rules/850cbf45fbf37966f62bc41780c050c3 /ngfw/var/cisco/deploy/sandbox/exported-files/var/sf/detection_engines/6e9f3a88-fb89-11e9-b0e5-212d508a897f/so_rules) with rcode 23\nstdout: \nstderr: rsync: link_stat \"/ngfw/var/cisco/deploy/sandbox/modulepack-pkg/so_rules/850cbf45fbf37966f62bc41780c050c3\" failed: No such file or directory (2)\nrsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1189) [sender=3.1.3]\n\n","key":"DeploymentError"}],"error_code":"device_failure_configuration"}}}
posArguments : DeploymentError;;;Sep 24 03:48:59 copytree failed: (/ngfw/usr/bin/rsync -a -L -K -O --no-owner --no-group --no-perms --safe-links /ngfw/var/cisco/deploy/sandbox/modulepack-pkg/so_rules/850cbf45fbf37966f62bc41780c050c3 /ngfw/var/cisco/deploy/sandbox/exported-files/var/sf/detection_engines/6e9f3a88-fb89-11e9-b0e5-212d5,
Transaction ID: 94489283403
Device UUID: ccd5023c-fb88-11e9-8817-e312508a897f
Chakshu Piplani
If you are getting a failure in subsequent deployments as well I would suggest you to contact TAC as they can revert to the old SRU update, and then help you re-install this one, as I'm suspecting this to be an issue due to SRU, which is causing the deploy to fail.
Chakshu
Do rate helpful posts!
Do rate helpful posts by leaving your kudos/mark it as solved.
is it possible to apply the configuration without this error, can't change configuration ftd
I do see the new SRU came out today Cisco_Firepower_SRU-2021-09-28-001-vrt.sh.REL.tar, try installing that on FMC and then push a deployment.
Chakshu
Thank you!
SRU-2021-09-28-001-vrt.sh solved a problem
